Do you change/version control at all?
If so what do you prefer to use?
- I have not yet connected Visual Studio directly to SWIS but if I get time to do that then TFVC might be my next step…unless theres something even better?
You can use whatever version control system that suites your environment. There really isn't anything specific about SWIS/SWQL to dictate a certain type of version control.
Thanks!
I am leaning toward TFVC since it seems most compatible with Visual Studio, MSSQL Server Management Studio, our TFS/Sharepoint and if I can get it to work with my Mac through the command-line client.
If I can get the WSDL imported into Visual Studio then I think I'm golden.
