I ran the migration utility and I thought it worked successfully at first. However, after auditing the AM to APM conversion I have found that 100+ applications did not move over. So I have approx half of the applications migrated, meanwhile I have a ton that did not. What do I do now? I'm afraid that if I re-run the utility I will have 100+ duplicates, however if I don't run the utility I will have hours upon hours of work to recreate these watches. Advice?
