I am using NCM to collect hardware info (serials, licences etc.) from switches. Process looks like
1. NCM connect to switch,
2. Execute command (Avaya: show system)
3. Save output
4. After that disconnect command cannot be done!
Does anybody have similar problems?
Except from trace:
[10/05/2016 08:55:37] SendNextCommand Done: Disconnecting
[10/05/2016 08:55:38] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=3 - Connected to server - idle
[10/05/2016 08:55:38] Pending Disconnect = True
[10/05/2016 08:55:38] Disconnected - From: 10.156.36.241
[10/05/2016 08:55:40] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:40] Pending Disconnect = True
[10/05/2016 08:55:42] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:42] Pending Disconnect = True
[10/05/2016 08:55:44] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:44] Pending Disconnect = True
[10/05/2016 08:55:46] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:46] Pending Disconnect = True
[10/05/2016 08:55:48] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:48] Pending Disconnect = True
[10/05/2016 08:55:50] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:50] Pending Disconnect = True
[10/05/2016 08:55:53] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:53] Pending Disconnect = True
[10/05/2016 08:55:55] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:55] Pending Disconnect = True
[10/05/2016 08:55:57] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:57] Pending Disconnect = True
[10/05/2016 08:55:59] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:55:59] Pending Disconnect = True
[10/05/2016 08:56:01] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:01] Pending Disconnect = True
[10/05/2016 08:56:03] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:03] Pending Disconnect = True
[10/05/2016 08:56:05] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:05] Pending Disconnect = True
[10/05/2016 08:56:07] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:07] Pending Disconnect = True
[10/05/2016 08:56:09] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:09] Pending Disconnect = True
[10/05/2016 08:56:11] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:11] Pending Disconnect = True
[10/05/2016 08:56:13] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:13] Pending Disconnect = True
[10/05/2016 08:56:15] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:15] Pending Disconnect = True
[10/05/2016 08:56:17] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:17] Pending Disconnect = True
[10/05/2016 08:56:19] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:19] Pending Disconnect = True
[10/05/2016 08:56:21] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:21] Pending Disconnect = True
[10/05/2016 08:56:23] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:23] Pending Disconnect = True
[10/05/2016 08:56:25] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:25] Pending Disconnect = True
[10/05/2016 08:56:27] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:27] Pending Disconnect = True
[10/05/2016 08:56:29] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:29] Pending Disconnect = True
[10/05/2016 08:56:31] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:31] Pending Disconnect = True
[10/05/2016 08:56:33] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:33] Pending Disconnect = True
[10/05/2016 08:56:35] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:35] Pending Disconnect = True
[10/05/2016 08:56:37] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:37] Pending Disconnect = True
[10/05/2016 08:56:39] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:39] Pending Disconnect = True
[10/05/2016 08:56:41] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:41] Pending Disconnect = True
[10/05/2016 08:56:43] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:43] Pending Disconnect = True
[10/05/2016 08:56:45] TimerTick: mstrData=<A00000F1; Nortel ES2526T; Test #> State=0 - Disconnected from server
[10/05/2016 08:56:45] Pending Disconnect = True
