Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NetFlow Traffic Analyzer (NTA)
Interface Issues
patwill66
I am having a problem with Netflow. This may be Cisco related and not Orion.
I am using these commands to enable Netflow on my routers:
interface GigabitEthernet0/0
ip flow ingress
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination xxx.xxx.xxx.xxx 2055
After doing these commands, I am seeing Netflow information for all interfaces on the router that are up. From the Netflow documentation on Cisco's site, they make it sound like if you enable it on an interface, you will only receive Netflow information for that interface. They never come out and directly say it but they talk about how Netflow needs to be enabled on every interface that you want the information from. Like I said, I am seeing ingress and egress information for every interface on the router.
Any ideas? I may just open up a TAC case and ask an engineer but I figured I would post something first.
Find more posts tagged with
Accepted answers
All comments
mstevens
IM having same issue. we have one router with 50 VPN tunnels so when I enable cache flow on an Ethernet Interface, all 50 VPN tunnels are added
adriang5555
Same problem here as well, using the exact Cisco Netflow commands suggested in the Solarwinds Netflow setup docs.
Dan.Wendeln
The examples given are to some extent generic and meant to get you on your way with Netflow statistics. There are caveats for various hardware/IOS combinations. 4500 series routers for example may require "ip flow ingress" to be changed to "ip flow ingress infer-fields". For more information you can refer to Cicso here
www.cisco.com/.../products_configuration_guide_chapter09186a0080233fe4.html
Dan Wendeln
SolarWinds.Net
Customer Support Services
patwill66
I did verify with Cisco that when NetFlow is enabled on an interface, it will show stats for the entire device and all interfaces on the device. It doesnt make much sense to me that you enable the commands on an interface level but it affects all interfaces on the system.
The TAC engineer gave me this link for some additional NetFlow information.
www.cisco.com/.../nfwhite.htm
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
