Does anyone here has successfully created Custom Properties for IPAM?
1. Go to Settings >> All settings.
2. Then Go to Manage Custom Properties.
3. Add custom Property.
4. Choose the Custom Property Object Type. IPAM Group Nodes is for Subnet Level, Groups, Hierarchy Group and Supernet.
5. Choose Properties. Make Sure the Property Name is unique and does not share any name for the IP Address Column currently existing to avoid Conflict.
6. You can put in some values. In this example, I just left it blank.
7. Counter check it on the Manage Subnet and IP Addresses Part of the IPAM.
Thank you!
