I am tinkering and trying to find out if it is possible to do a mass uninstall of different versions of Java on our network. I have the java 8 update 45 and set it to install but I am having trouble getting the uninstall to work first. Any suggestions on removing different versions of Java from the network with patch manager? I was thinking about maybe writing a script or something and seeing if I could get that to work.
