I can monitor memory and hard disk usage with the built in Monitors in ipMonitor.
Is there a probe that will monitor Virtual Memory?
I could create a custom SNMP probe on 1.3.6.1.2.1.25.2.3.1.6.5 (VM free) and check the value is less than 48959 (at least 64MB free - if my math is right).
But the problem is that the OID will be different on each server; and could change in the example below, if I unmapped drive Y: or modified the system by plugging in a USB drive
What I would like is a monitor that finds the entry in the hrStorage table that relates to the hrStorageVirtualMemory entry.
