I want to create a report listing all the interfaces of a switch with the duplex settings. How would I get this info?
You will need a UnDP to collect the duplex setting. Most (cisco) devices support the etherlike mib so 1.3.6.1.2.1.10.7.2.1.19 would be a good place to start. Then edit the Current Interface Status report in Report Writer to include the new data
Ok, I created the custom poller for that MIB. I then edited the report but I don't see how to display the results of the poller.
If the custom poller option doesn't appear in the drop downs you may need to experiment with other report types or it might be simpler to start a new report and select the sql option then paste something like
SELECT CustomPollers.UniqueName, Interfaces.InterfaceName, CustomPollerStatus.Status
FROM CustomPollerStatus INNER JOIN
CustomPollerAssignment ON CustomPollerStatus.CustomPollerAssignmentID = CustomPollerAssignment.CustomPollerAssignmentID INNER JOIN
CustomPollers ON CustomPollerAssignment.CustomPollerID = CustomPollers.CustomPollerID INNER JOIN
Interfaces ON CustomPollerAssignment.InterfaceID = Interfaces.InterfaceID
WHERE (CustomPollers.UniqueName = N'dot3StatsDuplexStatus')
into it
Add as many fields from the interfaces table as you need
dot3StatsDuplexStatus should be replaced by the name you gave your UnDP
FYI, this UnDP didn't work for me for my routers, but the UnDP here did. good luck
