Webcast – April 23 at 11am EDT
SolarWinds server monitoring is now turbocharged with the recent release of Version 5.5 of Server & Application Monitor (SAM) – formerly known as Application Performance Monitor. If you have not yet downloaded SAM or already own SAM / APM, then you should attend and see the powerful new features just added to SAM 5.5.
SolarWinds is well known by Network Operations teams in the Air Force (and other branches of the military) for having powerful yet easy to use tools for monitoring their network and server infrastructures. With the recent release of Version 5.5 of SAM, you can now extend the SolarWinds monitoring of your servers to a much deeper level – including virtualization and disk drive performance metrics, and even allow remediation of basic application issues right from the SolarWinds SAM interface.
Join us for this webinar to learn how “brains meets brawn” in SAM 5.5. SAM lets you do deep monitoring of your Applications, Servers, and Virtualization Environments, all with the ease-of-use that SolarWinds network products have been delivering for years. You will hear from SolarWinds federal experts how the Air Force, and every other branch of the military are using SAM for agent-less monitoring of applications and servers, as well as alerting, reporting, and (now) remediation. You’ll also hear about the new capabilities added in the latest release of SAM, and how Air Force, and other branches of the military can most benefit from these new features.
In this webinar you will:
- See how “brains meets brawn” in the latest release of SAM with these new powerful features:
- NEW remediation abilities including: start, stop & restart services, terminate rogue process and reboot servers
- NEW deployment architecture for enterprise scalability
- Install remote pollers for easy monitoring of remote locations
- NEW multi-vendor hardware monitoring for HP & Dell blade chassis systems
- Power Supply, Fan Speed, Temperature, and more…
- NEW Windows volume mount points monitoring
- NEW Windows storage performance monitoring metrics
- Disk Latency, Disk Queue Length, Disk IOPS, For both Virtual Disks and Physical Disks
- NEW Windows Server network interface monitoring
- NEW integration with Systems Center Operations Manager (SCOM) 2012
- Alerts sent from SAM to SCOM and Performance data sent from SAM to SCOM
- See how with SAM you create nested maps that can provide “at-a-glance” high-level status of critical servers and applications, while also supporting interactive drill-down capability that is all accessible from a standard web browser
- See how SAM can be downloaded, installed and configured to monitor your servers and applications in less than an hour, all while remaining easy to use, and easy on your budget
Register Now!
