Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.Data.SqlClient.SqlException: Invalid object name 'VoipSites'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlDataReader.ConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at SolarWinds.Orion.Common.SqlHelper.ExecuteReader(SqlCommand command) in C:\Source\OrionNPM\DEV\Release\Orion\Core\9.1\OrionCommon\Utility\SqlHelper.cs:line 112
at SolarWinds.Orion.Voip.Data.Site.GetAllSites()
at SolarWinds.Orion.Voip.Web.Site.GetAllSites()
at SolarWinds.Orion.Voip.Web.Site.GetAllSitesWithCallPaths()
at Orion_Voip_Resources_Summary_SitesOverview.SitesRepeater_Init(Object sender, EventArgs e)
at System.Web.UI.Control.OnInit(EventArgs e)
at System.Web.UI.WebControls.Repeater.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Control.AddedControl(Control control, Int32 index)
at System.Web.UI.ControlCollection.Add(Control child)
at Orion_ResourceContainer.ResourcePlaceHolder_DataBind(Object sender, EventArgs e)
at System.Web.UI.Control.OnDataBinding(EventArgs e)
at System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding)
at System.Web.UI.Control.DataBind()
at System.Web.UI.Control.DataBindChildren()
at System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem)
at System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource)
at System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e)
at System.Web.UI.WebControls.Repeater.DataBind()
at Orion_ResourceContainer.DataBind()
at Orion_Voip_Summary.OnInit(EventArgs e)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
