Hi Chaldz,
This is currently a feature request. I have created a case for you and attached it to the feature request in question. I will notify you if and when this is implemented within a future build.
Sincerely,
Chris Foley
I would like this also.
Hello Teecee,
In order to add you to the Feature Request and notify you if and when it becomes available, we will need you to submit a case at http://www.solarwinds.com/support/ticket. You can also open a case, like Chaldz did, by calling the Solarwinds Support Department at 866.530.8040.
Thanks in advance.
Has this been addressed in version 10?
I would really appreciate if any one can answer this
If NMS shows switches interface is Transmitting 100 Mbps, what I would consider overall link utilization would be 50 % or 100 %??
