I have an interface that is monitored on each of our NPM servers. on EOC global Top 10 whatever This Hour the reported results are different. Is this a UDT thing or something else?
Kevin
Just to clarify, when you check the Transmit Discards value for this interface directly in those NPM servers, can you see the same value on both servers? In other words, is the value consistent in those 2 NPM servers, just EOC reports it incorrectly?
Jan
