There appears to be a limit on the length of a Node that VoIP Monitor will allow. If I have a node called "NORTHLITTLEROCK-AR-RTR01", it will not display in the list of available VoIP Simulation Nodes. (Not to mention the fact that this scroll window list is much too narrow.)
If I shorten it to "N-LITTLEROCK-AR-RTR01", then this will be displayed as a node after I refresh the list. (actually only part of the name displays since the windows truncate the view)
Two items then seem to need to be addressed...
1) Please lengthen the limit acceptable for a node name in VoIP monitor to the same limit as enforced by Orion
2) Please widen each of the windows to be able to see either all of a node name, or allow it to be scrolled sideways so we can see the entire name.
Thanks very much.
