I've seen a couple posts but no real answers.
We are currently demo'ing the Orion NCM but if it can't manage all of our devices we will pass on purchasing.
We have a mix of Cisco equipment, which seems to be managed fine, and Motorola Symbol WS5100's and ES3000's that we need to manage.
I found the work around that suggests editing the template for the Motorola. So I now have this:
<!-- edited with XML Spy v4.4 U (http://www.xmlspy.com) by () -->
<!--Copyright 2005 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="Motorola BSR64000" SystemOID="1.3.6.1.4.1.4981.4.1.1">
<Commands>
<Command Name="RESET" Value="terminal width 0${CRLF}terminal length 0"/>
<Command Name="Reboot" Value="reload${CRLF}Yes"/>
<Command Name="RebootAt" Value="reload at ${HH}:${NN}${CRLF}Yes"/>
<Command Name="EnterConfigMode" Value="configure t"/>
<Command Name="ExitConfigMode" Value="end"/>
<Command Name="Startup" Value="startup"/>
<Command Name="Running" Value="runn"/>
<Command Name="DownloadConfig" Value="Show ${ConfigType}"/>
<Command Name="UploadConfig" Value="${EnterConfigMode}${CRLF}${ConfigText}${CRLF}${ExitConfigMode}"/>
<Command Name="DownloadConfigIndirect" Value="copy ${ConfigType} ${TransferProtocol}://${StorageAddress}/${StorageFilename}"/>
<Command Name="UploadConfigIndirect" Value="copy ${TransferProtocol}://${StorageAddress}/${StorageFilename} ${ConfigType}"/>
<Command Name="EraseConfig" Value="write erase${CRLF}Yes"/>
<Command Name="SaveConfig" Value="write memory"/>
<Command Name="Version" Value="show version"/>
<Command Name="PreCommand" Value="netadmin${CRLF}"/>
</Commands>
</Configuration-Management>
where we added a "n" to the run command and add the PreCommand indicating the user as "netadmin".
We then go to add a node and change the execute scripts to using SSH (we don't allow telnet), change the login credentials to Device, enter cli as the username and our password for netadmin as the password. For some reason it appears to be passing cli twice using that as the username and netadmin as the password. which is failing. I opened a ticket - 185027
But any help in getting these set up would be greatly appreciated!!
Here's the trace:
User Access Verification
Username:
clicli Password: netadmin % Incorrect Login. Invalid Name/Password or Incomplete User Definition (eg. missing password)
