This article provides quick & basic steps how you can troubleshoot Solarwinds application in case of failure "SYSTEM DOWN" situation .
This article will cover following key points and more .
Quick fast resolution and isolation of your System Down issues
Server in isolated environment / Unable to send diagnostic to Solarwinds or WebEx session not allowed
Faster response from Solarwinds Tech Support Center
Performance and Health Check / Resolving Performance issues
Tips and Tricks opening up Support Ticket with Solarwinds
Common System Down Situations
✘ Orion Web Console is Down
✘ Orion Polling is Down
✘Orion Services flapping
✘Orion Server is not responding
✘Orion Web console loading with Errors
✘Orion Server Disk is filling up quickly
Orion Services Manager If you have noticed any service is flapping / Unable to start follow the steps.
Check free disk space on Orion Server & SQL server
Check if you are using SQL Express Edition which have 10 Gig limit
Disable antivirus
Clear C:\Windows\Temp folder
Reboot the System (If there is any pending for Windows update ) and check the Services are backup UP
Check if there is any other user is not logged on to the Orion Server > Task Manager > Users (Log off them)
Logon to the Orion Server with Local Administrator account (NOT WITH DOMAIN ADMIN)
Then repair the Solarwinds Orion Core Service & Configuration Wizard as below
- Log in to Orion NPM Server as a Windows Local Administrator.
- Click Start > Control Panel > Programs and Features.
- Right-click SolarWinds Orion Core Services, and select Repair.
After the repair, the Configuration Wizard will launched.
Complete the Configuration Wizard just clicking NEXT & YES options
Note that configuring the website might take a few minutes.
Complete the above steps and then check the Services are backup again ?
Please Note: Evaluation period is expired (Syslog & Traps )✘ services will not Start.
Important Note: While Running the Configuration Wizard > Keep opening the Orion Service Manager > Make Sure all Orion Services keep on STOPPED state .
If you noticed any service is Flapping during the Configuration Wizard hit the "Shutdown Everything" on the Orion Service Console until you see the Configuration Wizard reached to Configuring Website portion
Important Note:
While running the Configuration Wizard Open the Task Manager > Make sure the CPU and Memory is stable and have not reached up to 100% utilization for longer time period specially when the Solarwinds Services will be started by the Configuration Wizard in the last stage.
Failure Situations :
✘ Orion Service repaired failure refused to repair
✘Configuration Wizard failed to connect to the Orion SQL Server
✘ Configuration Wizard failed with Database Configuration Failure Error
✘ Configuration Wizard failure with Website configuration failure
Configuration Wizard failed with website failure ? Please use the below KB post
Rebuild the Orion Website - SolarWinds Worldwide, LLC. Help and Support
Still have Error
Search in the Solarwinds Success Center
Success Center - SolarWinds Worldwide, LLC. Help and Support
Success Situation :
Configuration Completed Successfully and all Orion Services are back online
Wait for 10 main
Verify through log file . Open the below log file scroll to the bottom .
C:\ProgramData\SolarWinds\Logs\Orion\BusinessLayerHost.log
Last line will show you about service status.
INFO SolarWinds.BusinessLayerHost.BusinessLayerHostService - All plugins started
Success but System performance issues ?
High CPU / Website Performance issues please check the KB post.
Tweaking performance of Windows Server on Orion Platform products - SolarWinds Worldwide, LLC. Help and Support
My Orion Website & Server is very slow / CPU & Memory Spike /Polling gaps what should i check quickly ?
Orion Service logs.
Orion logs are always available under this location (ProgramData is system hidden )
For Example :
Orion JobEngine is Flapping and Unable to Start .
Open this log file below . (Scroll down to the bottom of the file and check what type of Error you have while this Service failure)
C:\ProgramData\SolarWinds\JobEngine.v2\Logs\SolarWinds.JobEngineService_v2_13.log
Solarwinds Information Service V3
C:\ProgramData\SolarWinds\InformationService\v3.0\Orion.InformationService.log
Solarwinds Recommendation Service is flapping
C:\ProgramData\SolarWinds\Logs\Recommendations\Recommendations.Services.log
SolarWinds Cortex Service flapping
C:\ProgramData\SolarWinds\Logs\Cortex\cortex.log
Configuration Wizard logs
C:\ProgramData\SolarWinds\Logs\Orion\ConfigurationWizard.log
Tips and Tricks opening up Support Ticket with Solarwinds.
Always provide details / Screen shots Or you can upload a Small Video recording about the application behavior where its needed.
Lets Start .
Open up MS word document
Add all screen shots of your issue in the world document and add some description on each of them
If you have any service flapping issue
Take a screen shot of the Orion Service Manager with Service Flapping
Take Screen shot of Task Manager each Tab
If you have any Error with Configuration Wizard failure take screen shot
If your web console is working go to the > Settings > All Settings > Polling Engines (Take Screen shot)
Please must answer these questions
- Time and date issue first occurred
- Describe Any changes at that time the you may have done
Provide details when this issue occurred changes are been made any Windows update / HF Upgrade
- In depth description of your issue
- Include references to screenshots and exactly what happens when the issue occurs in world document
- Troubleshooting steps taken:
- Include all the troubleshooting steps you’ve taken for this issue.
- Have you tried search the Error issue n the Solarwinds Success Center
- Please provide the KB link which you have already tried
- Please make sure you have listed everything you have tried.
- Please add bullet point steps you have taken and in what order
- Is there Interesting errors:
- Include any interesting log errors you found
- Steps to reproduce:
- If this is reproducible (even intermittently), note the exact steps taken to reproduce the issue in world document
- Your direct line phone number
- Your City Location
- Your working shift / TimeZone
Now Collect your Solarwinds Diagnostics
Open Support Ticket
Ticket Subject : Always add the Error in the Subject what you have in the screen shots / or in the Service Logs .
Now attach the Word Document with the ticket
Once Done .
Upload the diagnostic with the ticket number you have received.
Reply to the ticket email that you have uploaded the Diagnostics
Job Done.
