We purchased NPM and NTA, but we cant figure out how to activate the install with the keys we received since the trial is expired.
Thanks.
You have to be on the server. From there in your start menu there should be a "Solarwinds License Manager" from there just follow the prompts. Your licence keys should be on the Customer Portal Webpage. login and under license and maintnence tab is where you will find the license keys!
Hope this helps!
