Does Kiwi Cat tools support the integration with HP Open View or BMC ??
Regards
Hi Creativity44:
I would suggest using a database import, as CatTools is only designed to run against the CatTools database.
It's easy to do this. Just export the data from the 3rd party database/application into a tab delimited file format then import into the CatTools database. http://www.kiwisyslog.com/help/cattools/mnu_filedbimportdevicefrmtab.htm
--Christine
Hi creativity--
I've marked this for the PM to review.
M
Hi-could you help me understand what you mean? What are you trying to do?
Thank you!
Christine
In the production, the company uses HP open view and some database application from BMC. The management would like to know the possibilities of integrating the HP open view and BMC with Kiwi to share the info.
