I am using the Time Difference Between 2 Windows systems script with an external process monitor and I need some assistance. I can get the monitor to work but it never returns an alert. For example: I tested the following from the command line
c:windows\system32\cscript.exe "C:\Program Files\ipMonitor7\scripts\time_difference.vbs" server1 server2 0.000001
and it returns the correct times and the time is "greater than" However, when I put these same parameters in the external monitor it never alerts and is always returning a 0 value when it should be getting a 1 value.
Can anyone help with this?
