IPMonitor is not auto detecting additional drives other than the primary. How do I monitor a second drive? We looked into shares, but IPMonitor is not detecting them on the secondary drive.
Thanks for the help
Hello lemmiwinks,
Did you ever figure this out? If not, what Communication Type are you using within the Drive Space monitor?
If you open the Drive Space Monitor for the C: drive and then click the "Select" button, does it list the other drives?
Let me know,
Chris Foley - SolarWinds - Support SpecialistSupport:866.530.8040 || Fax:512.857.0125network management simplified | solarwinds.com
