hello everyone,
does anyone have an idea how i can change a device from "managed" to "ping only" ?
yes, i know, click the device -> properties, etc. that's not an option.
i'm talkin' bout 1000 cisco 836 routers ;-)
regards,
josch
well, we gave up the idea of changing the routers to ping devices.
is it possible to change the monitored interfaces for multiple nodes ?
we'd like to monitor the cpu of the routers, nothing more.
anybody has an idea ?
If you are SQL savvy you should be able to acomplish what you want by editing the Orion database directly. You'll want to make sure that the services are shut down before you make any changes. I found out the hard way you need to have then sutdown otherwise you edits don't stick.
Cheers,
You can delete interfaces, nodes, etc. using the Orion database manager.
Here is one post of a few describing how to do this.
Thank you, Ng, I'll give it a try.
cheers,
