I am looking to make a custom dashboard with all the same content as the Administrator Dashboard but for only a small subset of servers. Is this possible and how would I go about doing it?
It is possible but takes a little work. You can copy or create the existing widgets to a new dashboard and edit the search query behind each widget to only pick up the items of interest. Related post
Jon
Yes, you can do this by using "Account Limitation" feature when you configure user accounts:
Alex,
The screen you are showing is for Orion, not for Virtualization Manager.
TonyM - Currently, following JR's comment is the best way to go. We are working on solving this for the next version of VMAN with the Orion integration.
Ooops, sorry, I was digging for something myself and came across this question. Didn't check which product it relates to. My appologies
