I am having difficulty getting a File Count Monitor to work correctly, so I was comparing the settings in it to those of the Directory Size Monitor, specifically how the Fll Directory Path is configured.
If I input the exact same file path into both monitors, I get a successful test on the Directory Size monitor, but I get the error "directory not found" for the File Count monitor.
Is there some subtle difference in configuration that I am not aware of?
Can someone help me with formatting the settings for the File Count monitor? Thanks you.
