So I'm deploying Office 2013 Professional, and removing Office 2010 Home and Business. Unfortunately, since Access isn't part of Office Professional 2013, the Office 2013 installer leaves access installed and it needs to be removed. I have the following in PackageBoot (attached in pic). My commands work fine if done manually.
I get the following error when trying to deploy this package, and I'd love to know what I'm doing wrong.
2013-05-28 15:15:36:695 4432 1380 Handler :: START :: Handler: Command Line Install
2013-05-28 15:15:36:813 4432 1380 Handler :::::::::
2013-05-28 15:15:36:939 968 10e0 Report Uploading 4 events using cached cookie, reporting URL = server.local:8530/.../ReportingWebService.asmx
2013-05-28 15:15:36:955 4432 1380 Handler : Updates to install = 1
2013-05-28 15:15:36:962 968 10e0 Report Reporter successfully uploaded 4 events.
2013-05-28 15:15:37:065 4432 1380 Handler HandlerSecsInADay = 86400.
2013-05-28 15:15:44:358 4432 1380 Handler : WARNING: Command line install completed. Return code = 0x00000002, Result = Failed, Reboot required = false
2013-05-28 15:15:44:484 968 1684 AU >>## RESUMED ## AU: Installing update [UpdateId = {E4486761-5496-4C7F-AAC9-1E365A2E62A8}]
2013-05-28 15:15:44:484 968 1684 AU # WARNING: Install failed, error = 0x80070643 / 0x00000002
2013-05-28 15:15:44:484 4432 1380 Handler : WARNING: Exit code = 0x8024200B
2013-05-28 15:15:44:595 4432 1380 Handler :::::::::
2013-05-28 15:15:44:713 4432 1380 Handler :: END :: Handler: Command Line Install
