Hello,
Using exchange with a SAN, we have a mounted volume we need to monitor the size on it, so the path would be C:\MountName
We are running IPM v10, can this be done?
Brian
Hello Brian,
Some of our clients are successfully doing this using the Drive Space Monitor with WMI as the Communication Method. The only problem with this solution is that there is an issue with the WMI Performance class being used where the total drive size is much much higher than it should be. As a result, the % free space is being misreported. We are aware of this issue and the next release of ipMonitor should use a different WMI class to perform this task.
Sincerely,
Chris Foley - SolarWinds - Support SpecialistSupport:866.530.8040 || Fax:512.857.0125network management simplified | solarwinds.com
