Would like to ask, is it possible to install these WSUS and CONFIGMGR features of PM on the Patch Manager Server (Main)?
Where can I find the Product Features Selection from the installed PM with WSUS?
Thanks.
SolarWinds Online Help
you can enable configmgr features if you had turned off during the installation as per instructions above
hi, HolyGuacamole thanks for the response!
