Does anyone know how to backup a SSG-550 with Cat Tools.
I'm guessing you're using Device.Backup.TFTP? This is not supported in the juniper switch. Have you tried the Device.Backup.Running Config activity?
Chick - what problem are you having? Have you tried the Juniper device script to see if any would work?
--Christine
I'm gettin an error Device Type Juniper.Netscreen.Firewall has not yet had this functionality added. Skipping device.
Thanks Wardini thats working now.
