It would be great if you could add all commands like the Cisco Routers and Switches for HPN / H3C A-series like like display version, display interface brief ...
I can assist you with capture files.
Thx in advance
I also would really appreciate this!
I should be rather easy as they run comware as common operating system and the most stuff is very cisco like. I also volunteer as beta tester for getting this integrated.
I'need it too.
