Question...
What interfaces should I monitor on my Cisco Routers? Previously we had an NTA installation for just our division of the company. I had 3 routers to monitor. Rather easy, I monitored the Serial Connections to the T1 lines and the Gigabit connection to the LAN. After an upgrade I also began seeing MFR0 and MFR1 on our main router so I monitored those as well.
Now that we are rolling out a worldwide system I am getting routers that have over 600 interfaces when it finds the resources. Not all active but a good number are active. There are at least 4 or more Gigabit interfaces and 30 Serial. I want to be sure we are monitoring the correct interfaces in order to report problems quickly when they occur. However, with this many showing I'm not sure which ones are actually critical.
Any help would be appreciated
Karen
