Does anyone feed NTA with Gigamon generated Netflow? What does your infrastructure look like? What challenges did you have?
Since it seems the experience is low, I will discuss mine once the GMON architecture is transitioned from HD8 to a cluster of HC3s and the NTA is built.
We are in the process of setting this up now. I will let you know how it goes.We generate Netflow on an HC-2 and send it to Stealthwatch.We are adding a Solarwinds poller as a destination on our tunnel port.
-Paul
How did this work for you? Caveats? Limitations?
How did you separate the flows after getting to Solarwinds?
How did this work out for you guys? We use Gigamon to feed ExtraHop, but it would be nice if we could use it for NTA as well so that we don't have to maintain separate flows just for NTA.
