I was wondering if there was a quick way to uninstall USB Defender? I know you can run the remote uninstaller and then reinstall, but I was wondering if there was a way to just remove USB Defender without doing a full uninstall/reinstall?
Thank you!
If they were installed together, there's not an easy way (AFAIK) to remove USB Defender.
What you could do, though, is create a policy or script to set the USB Defender service to "Disabled" and "Stopped" and that would effectively kill the functionality.
