Hello,
I am trying to add a Moxa switch (Model EDS-G512E-T) to NPM, but I am having issues verifying the SNMP read/write string.
1. No connection errors
2. community strings (ro and rw) are both correct
3. I've done a packet trace and it appears that everything is working fine until the last exchange (set-request)
During the last exchange, I'm getting the error "error-status: badvalue (3)" and "error-index: 1" in the get-response.
I'm not sure what is causing this error and when checking the hex values, they appear to match. I can post the packet capture if needed.
Also, one thing we need is for solarwinds to pull the installed firmware information. I am able to pull this information manually with snmpwalk and with snmptest, but solarwinds cannot pull and display this information. The OID is not in the MIB tree, but I have added a universal device poller, but it will still not display the information (at least not anywhere that I can see). Is this just an issue of the the MIB needing the be added to the Orion MIB DB?
Thank you,
Stephen
