I've recently installed Toolset v10.8. I've had NPM up for 3 days. Why do all of my charts only show activity between 8am and 5pm? Is there a way to change it so I can see 24 hours of information?
Just for the record, it was an issue with the pc going into sleep mode.
Hi jsntyl,
Did you try modifying them by following the directions here?
Viewing ChartsToolset Network Performance Monitor provides a number of charts for viewing both object-wide summaries and specific object statistics.To view a chart:1. Navigate to the appropriate location in the tree pane. For example, to view a summary chart, expand Summary Charts. To view a chart for a specific SNMP enabled node, expand the node, and then expand the category of the property, for example, expand CPU Load and Memory Use.2. Click the chart you want to view.Notes:
Found in the AG on pg. 217.
I think when my pc goes to sleep mode, NPM stops polling. I'm going to make some pc adjustments and see if that helps. Thanks for your response. I'll comment on the post again if that is the issue.
