I have a unique issue, our Orion is on a network which requires SSL and IIS has to be set to accept client certificates. What this means is that I can't use NPM's report scheduler to email out reports since there is an additional click that a user has to do when clicking on a report. What I found is that NCM doesn't have this same issue as it uses a true report scheduler and doesn't attempt to open the report in a web viewer.
Is it possible to develop a report using SQL to point to the Orion NPM and use NCM to send the report?
Anyone try this or know if it is possible?
