This is an example of the altert email message:
${DateTime}
WEB TRANSACTION ${TransactionId}: ${Name}
LAST PLAYED: ${LastPlayed}
PLAYBACK INTERVAL: ${SQL:Select ${PlaybackInterval}/60} min
TRANSACTION STATUS: ${Status}
TRANSACTION DURATION: ${SQL:Select CAST(ROUND(${Duration}, 2, 1) AS DECIMAL(8, 2))} sec
STEPS WITH PROBLEMS:
${StepsWithProblemsFormatted}
Problem:
1. When the ${Status} is equal to Down... I get an SQL error message like the example below :
TRANSACTION STATUS: Down
TRANSACTION DURATION: MACRO SQL ERROR - Incorrect syntax near ','. sec
2. When the ${Status} is equal to Warning or Critical or UP... I get a nice formated Duration time like the example below :
TRANSACTION STATUS: Warning
TRANSACTION DURATION: 11.70 sec
My attempt to resolve was to offer an alternative to when the Duration would not have a time... as in a Down situation.
Can any of this be done like I have been trying to do using a CASE or IF statement?
The STATUS for these results was WARNING:
A
${SQL: Select CASE $Status WHEN $Status = 'Down' THEN '*****DOWN*****'
ELSE CAST(ROUND($Duration,2,1) AS DECIMAL(8,2)) END} sec
Result in email:
B
${SQL: Select CASE ${Status} WHEN ${Status} = 'Down' THEN '*****DOWN*****'
ELSE CAST(ROUND(${Duration},2,1) AS DECIMAL(8,2)) END} sec
Result in email:
${SQL: Select CASE $@Status@ WHEN $@Status@ = 'Down' THEN '*****DOWN*****'
ELSE CAST(ROUND($@Duration@,2,1) AS DECIMAL(8,2)) END} sec
C
${SQL:Select IF '${Status}' = 'Down' THEN 'Down' ELSE (CAST(ROUND(${Duration},2,1) AS DECIMAL(8,2)) END)} sec
Result in email:
MACRO SQL ERROR - Incorrect syntax near the keyword 'IF'.
Incorrect syntax near the keyword 'THEN'. sec
D
${SQL:Select IF (${Status} = 'Down' ) THEN 'Down' ELSE (CAST(ROUND(${Duration},2,1) AS DECIMAL(8,2)) END)} sec
Result in email:
E
${SQL:Select CASE '${Status}' WHEN 'Down' THEN '***** DOWN *****' ELSE CAST (ROUND (${Duration},2,1) AS DECIMAL (8,2)) END} sec
Result in email: 25.71 sec <-- Good result for Warning but not sure it would work when DOWN.
