Heya,
I'm trying to back up this switch configuration but Kiwi doesn't cover Telco Systems switches. I've tried using a default Cisco device config, but I get the error, "Cannot enter enable mode" when I run it.
Ideas anyone?
If you're familiar with VB scripting, you may want to try creating your own CatTools custom device script for your Telco Systems switch. (see http://www.kiwisyslog.com/help/cattools/dev_creatingcustomdevice.htm)
The template provided with CatTools is based on the Cisco IOS for a Cisco Switch, so if your Telco Switch is Cisco IOS 'like', you may find it only needs minor tweaking to get it to work.
If you have any luck, then please post back with your device script and we'll add it to the content share for others to use.
If you're not familiar with VB scripting, let me know.
Regards,
Steve
