I am trying to monitor an Extreme switch, but the program hangs during the resources discovery of the device with the message " Please Wait..Discovering Interfaces and Determining supported MIBS. 36 interfaces..."
Any ideas ?
I am not sure why it hangs.
You should have further information in the \Program Files\Solarwinds\Orion\NPM.BusinessLayer.log
and C:\Documents and Settings\All Users\Application Data\SolarWinds\Logs\Orion\OrionWeb.log files.
How many interfaces should be discovered on the device?
If you run a network trace using Wireshark it might give you some information as well such as which side stops sending information first.
HTH,
Yann
pastorm - Couple of things can cause this:
You can see both of these in an SNMP packet capture of the discvovery. Make sure you are using the latest version of the Toolset, as we are always trying to improve the discovery process.
Greg
RFC1213-MIB:ifNumberOID 1.3.6.1.2.1.2.1
RFC1213-MIB:ifTableOID 1.3.6.1.2.1.2.2
