My remote sites are connected via carrier ethernet, and layer 2 interfaces on various Cisco switches. I do not have routers at the locations. Is it possible to run IP SLA?
Using a non-core device as the SLA responder has several advantages.
Orion and VoIP Monitor have more frequent updates than might want to subject your core Cisco devices to.
VoIP monitor it is MUCH easier to monitor the links if it is given SNMP Write access to the SLA devices. This can be a bit risky in case Orion or the IOS in the device causes a problem when adding/removing SLA responders with the production core switches or routers. Having separate units for SLA only risks your stats gathering, not production traffic...
You already monitor the switches and links and so dropped packets and such will be in Orion for many of the L2 issues.
The VoIP devices (phones, call handlers, etc..) you have deployed are not the core switches themselves anyway, so it is the ability to carry the VoIP traffic between the sites which is the aspect you are interested in, not specifically which device is doing the testing...
I guess that is the point of my question. Is VOIP monitor a fit for my setup. Although the remote site is connected via layer 2, I still have a phone system and IP phones that need to contend for BW on the WAN link. I'm having some voice quality issues, and I'm looking for a way to monitor it.
I believe achrich is right, in that ip sla uses layer 3. Also, if your talking about cisco switches, that the native Cat ios does not support ip sla. I could be wrong,
Can you provide any detail on the kit your using to terminate the L2 ? If its a 4/6xxx Cisco switch you may be able to do some manual monitoring with it but you`d get more value if your running it on a router.
