I use ipMonitor 10 to monitor the interface bandwidth of several interfaces on a Juniper Netscreen firewall (running ScreenOS). ScreenOS supports the default RFC1213 MIB however, I can use it only for physical interfaces. If I have for instance a VLAN tagged interfaces and want to track the bandwidth on a per sub interface base, I have the use ScreenOS's custom MIBs.
I imported them into ipMonitor and can use them in SNMP wizard, however not in bandwidth monitor. With the normal SNMP monitor I only get the total bytes transmitted (or received) whereas bandwidth monitor calculates the current transmission rate based on the average of several samples.
Is it possible to use bandwith monitor with custom MIBs?
Regards,
Dominik
