I'm sure it's a easy one... but I can't find how to activate this specifique component.
When I try to click on Edit for AppInsight, I don't have the top menu to enable or disable components.
Here is the screen shot :
Thanks!
Some metrics are Exchange version specific. This component is disabled because it's not available on the version of Exchange you are currently monitoring.
Thanks for your answer, so in Exchange 2013 no way to do that?
I'm running Version 15.0 (Build 995.29) I wish I could have a monitoring for that... In the past we got some users that has been hacked by fishing mails… The hacker used these accounts to send a lots of “crap”... With that counter, I could see it right away if my exchange is sending more than usual.
The following Template(s) may be what you're looking for
