Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
problems with enable and download tool
FormerMember
Hello,
I currently have a scheduled task to download all of our configurations at a certain time.
As of late the report has come back with quite a few devices giving me the following error:
"ERROR: Cannot download Running config : Enable not supported or enable command invalid"
I can login just fine with the same credentials when going directly.
After some investigation with the session trace tool, it appears that the server is sending the enable command right after the username and before the password:
--> Username:
ProcessLogin State: 5
<-- monitoring@xxxxxx.com
-->enab
-->le
--> Password:
<-- xxxxx << enable password
--> % Authentication failed.
It appears that it sends enable and then enabled password but never the username's password.
here is trace for one that actual works.
-->monitoring@xxxxxx.com
ProcessLogin State: 2
--> Password:
<-- xxxxxxxx << username password
--> 2621-LAB>
ProcessLogin State: 3
Prompt is being set to : 2621-LAB>
Logging into Enable Mode
<-- enable
-->e
-->nab
-->le
-->Password:
-> 2621-LAB#
both routers are using the same auth. method and tacacs.
Anyone ran into this, or did I miss something?
Find more posts tagged with
Accepted answers
All comments
FormerMember
I am seeing the same thing with a few of my devices. Anyone have any ideas on this?
FormerMember
Robertp,
I actually found the problem. Our banner was causing the issue, it appears that it needs a space before the motd banner and after it. So I used rancid which doesn't seem to care to update all the nodes that weren't working
. and it worked after that.
FormerMember
Perfect, that worked for me too.
Thanks for your help!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
