Hello,
We have a a few switches which are "Stacked" together. We can pull the startups/running info from all of the switches except the first one in the stack (the one that holds the main configuration).
When you telnet into the first switch the credentials pull through but the switch goes to a menu asking which node in the stack do you want to enter. These are indicated by numbers.
Is there a way to have the device login with the given credentials, run a script entering the number of the device we need in this menu, then pull the config. I need this to be ran automatically without hand pulling.
Thanks in advance!
