Hi all, I'm currently testing the eminentware solution. I create a custom package of Firefox 10.0.2 and i want to execute a script after the firefox installation. The script is called by an autoit exe file. So i check use the package boot helper program and include my files : - post_script.exe (call .vbs) - post_script.vbs (delete firefox.lnk on the public desktop) Here my packageboot.xml, : <?xml version="1.0" encoding="utf-8"?> <packageboot version="1.0.0.0" id="8e283f7d-cca2-4d4d-90b5-bedf5f27d90d"> <instructions> <preexecution> </preexecution> <execution> <programs> <program type="exe" typeaction="runandwait" name="Firefox Setup 10.0.2.exe" successcode="0" failureaction="stop" enabled="true">-ms</program> </programs> </execution> <postexecution> <programs> <program type="exe" operation="runandwait" name="post_script.exe" successcode="0" failureaction="stop" enabled="true"> </program> </programs> </postexecution> </instructions> </packageboot> After the update, firefox is installed but the postexecution don't work. I tried with an other exe but without results. Can you help me with this ? Thx |
