There are many key topics I would like to discuss as features that we currently use with other IP SLA monitoring tools and very much like to transition these permanently to Solarwinds.
Item 1
Scheduling capability of IP SLA is fairly rich featured but current methodology available when using your SNMP SET capabilities is standard, start now, life, forever.
Item 2
Using the TAG field is common and often required to allow scheduled IP SLA pats to be used across more than one NMS system and additionally, makes it much easier to annotate in the setup of the router information about the type of test. Additionally, it is very important that solarwinds sets the OWNER field on the router when setting up these tests as well as support for showing that field when learning existing tests.
Item 3
Reaction trigger is a very useful feature for enabling traps such that ORION can get a more real time alert when the test passes some limit..common example is Packet loss exceeding 10% on UDP VOIP Jitter test.
