When I am looking at the polling engine rate for my primary poller will I also see IPAM overhead?
I want to increase the IPAM subnet polling intervals from 1day to 3.5hours and would like to know if I will see it here?
You'll need to click Settings in the upper right hand corner > IPAM Settings > System Settings >Config Default to change it.
Thanks -actually I did a table update to make it stick with the existing subnets.
But I am wondering if the polling IPAM does is factored into the Polling Engine rates - it's at 69% right now and I want to know if I increase polling times would I see it reflected in this polling engine rate %
Funny, I was wondering this same question this morning. I have almost 20,000 used IP addresses and I would like to see what impact this has on my polling engines. If it is reflected in the polling engine rate then that is a good start.
I'll respond here if I find the answer, I'll look in the knowledgebase during my next meeting :-)
