I'm trying to update the 'Comments' property on an already existing subnet using the orionsdk python 'update()' method, but it fails miserably (see code below).
What on earth am I doing wrong?
Also, I am trying to figure out if it is possible to create supernets or subnets within an already existing supernet using the Orion API?
Any help would be very much appreciated.
/BR, Espen
My python test code looks like this:
import orionsdk
swis = orionsdk.SwisClient('hostname', user, passwd)
uri = 'swis://localhost/Orion/IPAM.Subnet/SubnetId=6244,ParentId=109'
comments = 'MY-TEST-COMMENT'
swis.update(uri, Comments=comments)
API responds with this error (running inside ipython):
In [51]: swis.update(uri, Comments=comments)
HTTPError Traceback (most recent call last)
<ipython-input-55-133cfe3d54f8> in <module>()
----> 1 swis.update(uri, Comments=comments)
/home/eto/dev/venv-orionsdk/lib/python2.7/site-packages/orionsdk/swisclient.pyc in update(self, uri, **properties)
38
39 def update(self, uri, **properties):
---> 40 self._req("POST", uri, properties)
41
42 def delete(self, uri):
/home/eto/dev/venv-orionsdk/lib/python2.7/site-packages/orionsdk/swisclient.pyc in _req(self, method, frag, data)
57 pass;
58
---> 59 resp.raise_for_status()
60 return resp
/home/eto/dev/venv-orionsdk/lib/python2.7/site-packages/requests/models.pyc in raise_for_status(self)
933
934 if http_error_msg:
--> 935 raise HTTPError(http_error_msg, response=self)
936
937 def close(self):
HTTPError: 400 Client Error: The incoming request has too many parameters. The server supports a maximum of 2100 parameters. Reduce the number of parameters and resend the request. for url: hostname:17778/.../SubnetId=6244,ParentId=109
