Hello.
Good day.
Is there a way we can monitor the CPU Utilization for NetApp and V7000 Controller in SRM Orion?
If yes, please advise what object and field we need to locate in the trigger condition.
Thank you very much.
Kind Regards,
Leny
this was discussed in Netapp CPU Busy Percentage and currently there is anything like that, but if you can see on that post, it is already under a consideration.
Regards
Lubo
Thanks for the update.
Can you advise when would be the target release of this request? Thanks!
No problem.
Well, to be honest I do not know the timing. What I can tell is that this is under consideration and when that can be done and released, it is hard to tell now.
I would add that according to our policy, we even can't share any timelines.
Jiri
