I'm getting this error in my log when I try to CreateCorePluginConfiguration and then starting the discovery
2018-06-29 11:47:01,657 [53] ERROR SolarWinds.Orion.Core.SharedCredentials.CredentialDAL - (null) Unable to find credential with ID = 189, owner = and credentialType = SolarWinds.Orion.Core.SharedCredentials.Credentials.UsernamePasswordCredential
2018-06-29 11:47:02,282 [53] ERROR SolarWinds.InformationService.Core.InformationService - (null) Exception for Operation: <root type="array">
<item type="object">
<Name type="string">UNIT_TESTDiscovery</Name>
<EngineID type="number">1</EngineID>
<JobTimeoutSeconds type="number">3600</JobTimeoutSeconds>
<SearchTimeoutMiliseconds type="number">2000</SearchTimeoutMiliseconds>
<SnmpTimeoutMiliseconds type="number">2000</SnmpTimeoutMiliseconds>
<SnmpRetries type="number">4</SnmpRetries>
<RepeatIntervalMiliseconds type="number">1800</RepeatIntervalMiliseconds>
<SnmpPort type="number">161</SnmpPort>
<HopCount type="number">0</HopCount>
<PreferredSnmpVersion type="string">SNMP2c</PreferredSnmpVersion>
<DisableIcmp type="string">False</DisableIcmp>
<AllowDuplicateNodes type="string">False</AllowDuplicateNodes>
<IsAutoImport type="string">True</IsAutoImport>
<IsHidden type="string">False</IsHidden>
<PluginConfigurations type="array">
<PluginConfigurationItem type="string">"<?xml version=\"1.0\" encoding=\"utf-16\"?><PluginItems><knownTypes><ArrayOfstring xmlns:i=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns=\"http://schemas.microsoft.com/2003/10/Serialization/Arrays\"><string>SolarWinds.Orion.Core.Models.Discovery.CoreDiscoveryPluginConfiguration,SolarWinds.Orion.Core.Models</string></ArrayOfstring></knownTypes><pluginItem><ArrayOfDiscoveryPluginConfigurationBase xmlns:i=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns=\"http://schemas.datacontract.org/2004/07/SolarWinds.Orion.Core.Models.Discovery\"><DiscoveryPluginConfigurationBase xmlns:d2p1=\"http://schemas.solarwinds.com/2008/Orion\" i:type=\"d2p1:CoreDiscoveryPluginConfiguration\"><d2p1:ActiveDirectoryList /><d2p1:AddressRange /><d2p1:AgentsAddresses xmlns:d3p1=\"http://schemas.microsoft.com/2003/10/Serialization/Arrays\" /><d2p1:AutoImportVolumeTypes xmlns:d3p1=\"http://schemas.datacontract.org/2004/07/SolarWinds.Common.Snmp\" i:nil=\"true\" /><d2p1:BulkList xmlns:d3p1=\"http://schemas.microsoft.com/2003/10/Serialization/Arrays\"><d3p1:string>10.222.10.11</d3p1:string></d2p1:BulkList><d2p1:Credentials><d2p1:credentials><knownTypes><ArrayOfstring xmlns:i=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns=\"http://schemas.microsoft.com/2003/10/Serialization/Arrays\" /></knownTypes><pluginItem><d2p1:ArrayOfCredential xmlns:i=\"http://www.w3.org/2001/XMLSchema-instance\" /></pluginItem></d2p1:credentials></d2p1:Credentials><d2p1:DiscoverAgentNodes>false</d2p1:DiscoverAgentNodes><d2p1:PreferredPollingMethod>SNMP</d2p1:PreferredPollingMethod><d2p1:SharedCredentials xmlns:d3p1=\"http://schemas.microsoft.com/2003/10/Serialization/Arrays\"><d3p1:KeyValueOfintint><d3p1:Key>1</d3p1:Key><d3p1:Value>189</d3p1:Value></d3p1:KeyValueOfintint></d2p1:SharedCredentials><d2p1:SubnetList /><d2p1:WMICredentials /><d2p1:WmiRetries>0</d2p1:WmiRetries><d2p1:WmiRetryInterval>PT1S</d2p1:WmiRetryInterval></DiscoveryPluginConfigurationBase></ArrayOfDiscoveryPluginConfigurationBase></pluginItem></PluginItems>"</PluginConfigurationItem>
</item>
</PluginConfigurations>
</item>
</root>
Please help with this error.
