I'm using WPM to monitor some web transaction performance for while.
Just want to know how set WPM to monitor Internet Trading Web Application only Trading hour? (Mon - Fri @ 9.30-12.30 and 14.00-16.30)
Thanks in Advance,
Morakot
Hi, You can use UnmanagedEditor utility by default located at C:\Program Files (x86)\SolarWinds\Orion\UnmanageUtility where your Orion Server is installed. Usage is I think pretty straightforward, but let us know if you have any problem.
Petr
Thanks, Petr.
The limitation of Unmanage utilities can set only duration,
So, If I want to check web application only in trading hour (Mon - Fri @ 9.30-12.30 and 14.00-16.30)
I have to create 3 tasks to unmanage
Correct me If I'm wrong.. there's any easiler alternative method?
Yes, you will have to create 3 tasks to unmanage as you mentioned. Still I think this is the most easiest way to achieve your requirements, another way could be to use SWIS or SQL query but I think this will be far more complicated than this approach.
