Just did a brand new install on a fresh server and I am unable to get the module engine to start. Any ideas?
Open a support ticket please. It's hard to tell what may be wrong without looking at log files.
Thanks for the reply. I did open a support case however, I can't take to logs off of this system.
I am able to see the event viewer complaining about the Windows CRT binary. Stating that "it is not signed and can be a security risk".
Can you not run orion diagnostics?
If your installing, the logs will be available to read at the installation path?
Have you ran the config wizard as local admin, also the permission checker?
Cheers
