Dears.
I am very new of using kiwi sys log. I have a question!!
How I can get a list of all devices which sending logs to my kiwi syslog server/
Our default rule includes an action to log to a file. When configuring this action we use the 'AutoSplit' value to use the hostname as the log file name(C:\logs\hostslogs\%Hostname.txt). The hostlogs directory will then have a file for every host. From there you could do something like 'dir > hostlist.txt and use the text file.
From the menu, Click Manage\Debug options Look under the "Breakdown of Syslog messages by sending host" section. If you need more hosts, please see this link:
Kiwi Syslog Server
Thank you very much for your help. this is very useful.
Building on what kstone said, when using the auto-split function, make sure you are not also using Log File Rotation.
